Hello, I have a block that i want to make and i was curious if there was a way to make an attribute that is linked to the length of the block. I have the distance1 parameter and a stretch parameter in my block
Solved by Libbya. Go to Solution.
No attribute length cannot be changed, by stretching a block. It will always be fixed to what you set it as when you create it
Howard Walker
It depends on what you mean. You can change the attribute value based on the length of a linear parameter by using either a block properties table or a lookup. You cannot dynamically change the text width of a multiline attribute.
Basically the text will be invisible, i just want it to show up when we use the data extraction command so we can have the length in the table to make estimating and quoting easier
If you just want the text to show the length of a parameter then that is quite easy. No need for block properties table or lookup. Just use a blockplaceholder field in the attribute referencing the distance parameter.
