Dynamic Blocks Forum
Concentric Circles - Sized by Radial Distance from Adjacent Circle
2 REPLIES 2
apweng
330 Views, 2 Replies
Hi there,
I'm trying to create a block for farmland pivot irrigation system - the massive sprinklers you see on wheels for irrigating fields and rotate on wheels about a center pivot point.
Here are my parameters:
  1. Up to 10 concentric circles - I will use visibility states for these
  2. Radius of each circle will be constrained to a minimum and maximum value (I can do this)
  3. Radius of all but the center circle is based on specifying a radial distance from the next smallest circle
So I can create a dynamic block with 10 concentric circles, and use parameters and actions to size the circles by radius, but I can't figure out how to size all but the inner circle by specifying a distance from the next smallest circle.
Here's an image that may help explain - thanks!
2 REPLIES 2
Libbya
in reply to: apweng
Fairly straightforward.  I did three circles.  Just follow the same process for additional circles.  See screencast.
apweng
in reply to: Libbya
Well this is absolutely fantastic!  I chuckle at  your "fairly straightforward" comment as I will undoubtedly spend 2 hours absorbing and redoing what you did to make my block work - thank you very much!
I will for sure be following up with an additional question as I need to have a line drawn from the center to the extents of the maximum radius (with a symbol at the outer end point of that line, which would be inserted at the intersection of each circle).
Working with dynamic blocks requires a programmers mind for sure - thanks again!
Andy
Forma Design Contest
AutoCAD Beta
