- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there,
I'm trying to create a block for farmland pivot irrigation system - the massive sprinklers you see on wheels for irrigating fields and rotate on wheels about a center pivot point.
Here are my parameters:
- Up to 10 concentric circles - I will use visibility states for these
- Radius of each circle will be constrained to a minimum and maximum value (I can do this)
- Radius of all but the center circle is based on specifying a radial distance from the next smallest circle
So I can create a dynamic block with 10 concentric circles, and use parameters and actions to size the circles by radius, but I can't figure out how to size all but the inner circle by specifying a distance from the next smallest circle.
Here's an image that may help explain - thanks!
Andy
