Using the PDF Export from the File tab will allow you to set up your sheet set in the order you want it to print to a multiple-page pdf. Select the edit button that looks like a pencil.
Use the pulldown to just show Sheets and not all the other views in the project.
You must have some checked to be able to Edit print order.
The next dialog box, Edit Print Order in <in-session> appears allowing sorting by Browser organization, Sheet Number (Ascending), and Manual order. When choosing the Browser organization, the options for Sheets sort by: and Views sort by: appear for selections.
#CADMama #AutodeskCommunity #AutodeskExpertElite #Revit #Print
Did you have to be signed in to “Like” a blog post? When it comes to any blog post, sing it with me now, “If you liked it, then you shoulda put a “Like” on it. Sign in and sing it with me.
Donnia Tabor-Hanson, aka CADMama
Revit Family Counselor
Revit CSI
Revit Forensic
Twitter @DonniaTH
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
