XML Reporting Editor
There should be an editor for the report templates.  While editing the xsl style sheets is nothing more than editing a text file, the format and the lack of documentation make it a daunting task for a regular user.  Any of the VBA or .NET reports have to be edited by someone familiar with programming.
At the very least, simple formatting, data order and precision should be available for the user to change in the editor.
12 Comments
C3D_TomR
After seeing web design pages and surveys that are drag and drop, it would be so much easier for the average user to create and modify their own reports if that type feature was added to the reporting side of the software.
jmayo-EE
Formatting & creating your own report should be much easier. It would be real nice to be able to bypass using Excel or another program to get the report ready for printing.
dsimeone
Status changed to: Accepted
Thanks for your suggestion. Items related to Report Generation will fall under Portfolio Feature - PF1454.
C3D_TomR
Thank you, Dave.
wim_de_winter
A tool similar to the AutoCAD Plant3D Report Creator is usefull in AutoCAD Civil3D for reporting.
https://www.youtube.com/watch?v=FIItL1awUQk
wim_de_winter
AutoCAD Plant3D report designer
We, the users of Civil 3D need better options than xml/xsl reports, better options than hitting a "print" button and getting an html file in our temp folder.  We cannot keep having to revert to IE9 to get reports to function.  We need to be able to customize the content reporting.  We should be able to use a GUI based system that allows us to create FUNCTIONAL reports.
doni49
At the very least if you're going to insist on utilizing the web browswer to display the report, allow the user to create a template using HTML of how they want their report to look.  Provide "Starter" templates that are already compliant with the latest browsers.
troma
I should be able to format ahead of time what I want to see, rows, columns, units, precision display etc.
Then I should be able to have a report delivered to me in .xml, .pdf, .txt, .xls, .doc, .rtf as I choose. The report should be created and ask me where to save.
Getting a report should not depend on having an archaic browser set as my default.
ceethreedee.com
If you havent seen the project explorer by 3AM solutions. Then i suggest you check it out. It does a fantastic job of creating custom reports out of a "redesigned" toolspace. There is also a product from civil plus, called visual report designer, but its a little convoluted to use.
project explorer $600 , VRD is about $800. right now VRD supports calculated fields though and Project explorer doesnt. Im talkign to the developer to get him to add it soon though.
Despite all this though, i would like to see C3D team either buy one of these products and incorporate it into core, or produce somethign similar to it.
neyton_
Try this app to create reports :
http://tbn2net.appspot.com/showprog?progid=NOTASERV2
And this to create parcels reports :
http://tbn2net.appspot.com/showprog?progid=C3DMEMO
TimYarris
With the release of Project Explorer for Civil 3D, I'm marking this issue as Implemented.
Please watch this video for a high-level overview of setting up a custom report template in Project Explorer.
