SAC Create U-shaped concrete channel
Beka_Tchigladze
Advisor Advisor
Message 1 of 15
Beka_Tchigladze
So I have a challenge, to create U-shaped water removal concrete channel, with subassembly composer. how is it possible to get different geometry to the elevation points of a baseline? as it is done here on the screens below?
this guy at the first time took a feature line and put an assembly on it, after he add elevation points and he have gotten different sections for each times. how can I do it in composer? if you give me some hints this would be perfect thank you in advance.
Beka Tchigladze
Infrastructure Design Engineer | BIM Automation Developer
Autodesk Developer Network (ADN) Member
Autodesk Certified Professional: Civil 3D & AutoCad
LinkedIn | Autodesk App Store
Replies (14)
Message 2 of 15
RonaldBrañez
Hi @Beka_Tchigladze
I recommend you use targets.
Create a channel section with at least the following targets (on both sides)
When creating the corridor you must have the elements that define the internal, external and elevation geometry (alignments, profiles and/or feature lines).
Regards.
Message 3 of 15
Beka_Tchigladze
@RonaldBrañez
Thank you for your replay but unfortunately this is not what I wanted. I want to use baseline class, not targets, targets are too complicated for this
Beka Tchigladze
Message 4 of 15
RonaldBrañez
@Beka_Tchigladze
Can you explain how "he add elevation points"? Where can I see the procedure you saw? Is it a youtube video?
It occurs to me that it can be processed as a transition
the input parameters:
Width0, Height0
Width1,Height1
Distance
PkStart
and using functions like Baseline.Station and conditionals to apply a specific width and height, for example:
Input parameters
Width0=1
High0=1
Width1=0.8
High1=0.8
Distance=2
PkStart=2.5
IF
Math.IEEEremainde(Baseline.Station-StartPk,Distance)=0
THEN
geometry with Width1 and Height1
ELSE
geometry with Width0 and Height0
(Note: IEEERemainder Returns the remainder resulting from the division of a specified number by another specified number.)
Taking into account that the main frequencies of the corridor must coincide with multiples of the Distance parameter, and there must also be frequencies very close to the main ones (0.001).
Regards.
Message 5 of 15
Beka_Tchigladze
@RonaldBrañez
https://youtu.be/UtIsBnrsnvI?t=3835
yes you can watch from 1:03:55
Beka Tchigladze
Message 6 of 15
RonaldBrañez
Hi @Beka_Tchigladze
He definitely used the procedure that I indicated in my previous answer.
He have in the subassembly:
Length (Distance)
Start and end width (Width0 and Width1)
Start and end high (High0 and High1)
It does not have PKStart since it uses progressive 0 from the base line.
The Length (Distance) defined in the SA coincides with the frequency of the corridor.
The elevation points it assigns do not define elevations, they simply serve to assign the elevation frequency of the corridor, the distance it assigns to the elevation points is 1 mm more than the horizontal frequency.
With this procedure you can do interesting things, only the creation of the SA needs a little more work.
For example this one I did.
Saludos.
Message 7 of 15
Beka_Tchigladze
@RonaldBrañez
Listen... I don't know who you are, but you are crazy really that you manage to do this culvert 🤔
Decent achievement 👏
Beka Tchigladze
Message 8 of 15
RonaldBrañez
@Beka_Tchigladze
I attach a SA similar to the video. (Change the extension to PKT)
I didn't put any codes.
I hope this helps you understand the idea.
Regards.
Message 9 of 15
Beka_Tchigladze
@RonaldBrañez
Thank you very much for this.
Beka Tchigladze
Message 10 of 15
rsalastopografia
Es sorprendente tus conocimientos en subassembly composer estimado, podrías indicarme los pasos para desarrollar el pkt de alcantarilla tipo tubería con sus aletas en ambos extremos en subassembly composer? espero puedas responder mi mensaje, saludos.
Message 11 of 15
RonaldBrañez
Hola@rsalastopografia
de hecho puedes encontrar el procedimiento en el siguiente post > Using SAC to make Cross drainage (Pipe culvert and Box Culvert)  <
Saludos
Message 12 of 15
rsalastopografia
Buen día estimado Ronald, algo esta mal en el enlace porque me redirige a una red social. te agradecería que puedas compartir los pasos del desarrollo de alcantarilla tipo tubería con aletas en subassembly composer, es un diseño bastante especial porque no se como hacer que se dibujen esos muros de las aletas y en el cabezal de la tubería con su espesor, además de asignar el ángulo a las aletas. tengo un caso de muro de contención con contrafuertes, el problema surge cuando algunos contrafuertes no son perpendiculares al muro y me surge la pregunta si podría asignarse un ángulo de rotación a algunos de los contrafuertes y los demás sigan siendo perpendiculares al muro. me ayudaría bastante obtener los pasos de la alcantarilla de tipo tubería con aletas para poder aprender y aplicarlo a otros subensamblajes; saludos.
Message 13 of 15
kristine93
Observer
Observer
j
Message 14 of 15
RonaldBrañez
@rsalastopografia  ha escrito:
Buen día estimado Ronald, algo esta mal en el enlace porque me redirige a una red social...
que raro.
Volví a revisar el enlace y abre correctamente el post del foro en el cual explico como realizarlo.
de todos modos te dejo nuevamente el enlace como para que lo copies directo en tu buscador
https://forums.autodesk.com/t5/civil-3d-forum/using-sac-to-make-cross-drainage-pipe-culvert-and-box-...
Message 15 of 15
rsalastopografia
Ahora si pude abrir el enlace, gracias.
