Message 1 of 15
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So I have a challenge, to create U-shaped water removal concrete channel, with subassembly composer. how is it possible to get different geometry to the elevation points of a baseline? as it is done here on the screens below?
this guy at the first time took a feature line and put an assembly on it, after he add elevation points and he have gotten different sections for each times. how can I do it in composer? if you give me some hints this would be perfect thank you in advance.
Beka Tchigladze
Infrastructure Design Engineer | BIM Automation Developer
Autodesk Developer Network (ADN) Member
Autodesk Certified Professional: Civil 3D & AutoCad
LinkedIn | Autodesk App Store
