Profile labels for Pressure Networks
tommcgtx
tommcgtx
I am working on a project that I didn't start, and can't really change the way it's been set up. That being said, here's the problem. There are two water lines, a raw water from wells, and a finished water that run parallel. Each water line has it's own alignment, and there is a baseline alignment running between the two. The profile view is based on the baseline alignment, and both water lines are shown on it. The fitting and appurtenance labels refer to the stationing of their own alignments, not the stationing of the baseline alignment. I had to add a station equation into the mix, with each alignment having it's own station equation. Each fitting and appurtenance is referenced to it's alignment, and each profile label is also referenced to it's alignment. The finished water line's labels update to the new equation station, but the raw water line's do not, and still reflect the pre-equation station. I can't seem to figure out why the two sets of labels are behaving differently. I would rather not manually edit each and every label individually to reflect the proper station.
tommcgtx
Interesting note, when I choose the reference alignment for the label (in the properties), the finished water alignment is listed 3 times. Two of these show the correct station when selected, one does not. The raw water alignment is only listed 1 time, and it does not work. There aren't 3 finished water alignments in the drawing, yet it shows up 3 times in this list. What causes this?
