Method 2 – Wall by Face Command
- Using the Wall by Face command (Building Maker tools), you can create non-vertical walls of various types and free-form design with mass objects of various shapes. The key thing to remember in this method is that you are creating walls by applying them to a face…no matter what shape or curvature of face.
Pro Tip: Explore the other Building Maker Tools while here…
Labels:
3 Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
