- Mute
- Permalink
- Report
This has been asked before. Specifically, this post (2020) detailing Elevation and ElevationExtended in ElevationScheme in IsoConfig.xml, this post (2012) detailing the same thing, this post (2013) that references the information in the first two posts, and this post (2015) that nobody answered.
The question is simple. On many connection and continuation callouts, the coordinates (X, Y, and Z) display by default. There's an option under project setup (annotations, connections and continuations) to turn these three off together. Some people have wondered if there's a way to disable just the X and Y coordinates, leaving the elevation on the annotation. The longstanding established answer is that you cannot directly disable two of the coordinates without also disabling the third. The only solution would be to edit the PCF files manually. As @h_eger notes [in the first post, above], you don't want to do that.
My question: can we turn off the automatic coordinates, but add the elevation/z-coordinate back on in some other way? I would suspect it has something to do with project setup, annotations, connections and continuations, then either the "Connection prefix" or "Connection text" fields (see attached screenshot). There's a button right by connection text that lets you select properties from a list, adding them into the connection text field surrounded by angle brackets.
The reason I'm posting to forums is because despite my tinkering, I haven't been able to figure out how to add elevation on. "<PipeRunComponent.Position Z>" and "<EngineeringItems.Position Z>" both seem promising, but I can't get them to actually produce anything on the tag.
In terms of help documentation, this article (2016) by AutoDesk Support suggests something of the like should be possible, while this article (2018) (also by AutoDesk Support) suggests you cannot do anything of the like without going into the PCF files.
I know I'm close. Does anyone know how to do this?
EDIT: Removed "\" characters in properties above. Using Plant 2020, but this should be universal (or at least applicable to many versions of plant).
