AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
how to change CONNECTION-REFERENCE format P3D2013
8 REPLIES 8
Message 1 of 9
1659 Views, 8 Replies
Hi
I didn't find how to change CONNECTION-REFERENCE format in P3D2013.
(I'm working in isoconfig.xml )
On isometric, at the end of the line connected to an equipment , the reférence of  Tag of equipment + the equipment nozzle tag + lb of the nozzle are concatened.
If I want just the equipment tag and the ND of the equipment nozzle how to configure the format ?
Thank
8 REPLIES 8
Message 2 of 9
Dan.Scales
Unfortunately the CONNECTION-REFERENCE attribute is hardcoded and cannot be changed.
I will log a wish with our developers for the ability to edit this connection text.
Dan
Dan Scales
Message 3 of 9
in reply to: Dan.Scales
Thanks Dan,
This save my time to find a solution.
I hope a quick devellopement ot this functionality
Sam
Message 4 of 9
Dan.Scales
Hi Sam,
Another approach to get the result you need could be:
  • Open the ISO annotation node in Project setup and place the text shown in the screen shot to the Connected equipment  nozzles connection.
  • Second, open ISOCONFIG.xml to remove “\P\P”(to remove the extra line break)
EndConnectionScheme Name="EndConnectionsEquipment" AnnotationStyle="Standard" Format="CONNECTED TO\P\P\P{0}\P{1}" LeaderStyle="AlwaysCorner" Filter="EndConnectionsEquipment" Fields="CONNECTION-REFERENCE CO-ORDS" />
  • The final result looks as below which contains only Equipment Tag and Nozzle size.
I hope this helps.
Dan
Dan Scales
Message 5 of 9
Great Dan !
Thanks,  it's works !
Sam
Message 6 of 9
hwood818
Does this also work on line continuations or only on continuations to equipment?
Message 7 of 9
dave.wolfe
in reply to: hwood818
It does both just select the matching annotation in the dialog.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 8 of 9
hwood818
It still isn't working for me. Perhaps I don't have the correct annotation properties. I can't find them documented anywhere and obviously I'm not a very good guesser. I've also found that this is maybe a known issue with Autodesk and version 14 may fix it?
Edited by
Discussion_Admin
Message 9 of 9
dave.wolfe
It's actually not possible to set this up in the isoconfig.xml. You need to use the project setup dialog.
The available properties and formatting are available here:
http://docs.autodesk.com/PLNT3D/2013/ENU/filesPCR/GUID-E5AB172A-9696-455F-B698-252CEA84CC07.htm
per Dan's answer above.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Technology Administrators
”Boost
