AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
remove coordonate x and y and save elevation isometric plant 3D
5 REPLIES 5
699 Views, 5 Replies
how remove coordonate x and y and save elevation isometric plant 3D
5 REPLIES 5
h_eger
dear @Anonymous ,
unfortunately it is not possible to remove the X and Y coordinates from the isometry.
These values are generated via the PCF file and the associated standard and are only adopted by Plant 3D Isometric.
There is no configuration option for this except to edit the PCF files manually. You don't want to do this ...
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
MateusMaciel
@Anonymous do you want to remove the X and Y coordinates in some exclusive annotation?
mateustilapa@gmail.com
Try this:
  1.
    Turn off/uncheck the Append Coordinates and Elevation box under project setup for each End Connection Annotation type.(see 1.jpg)
  2. Open the Isoconfig.xml, search for “ElevationScheme – Elevation” or “ElevationScheme – ElevationExtended” and set the Enable value to “true”, use either 1 or 2 depending on how you want your elevation to be displayed.
    1. Choise 1 (see 2.jpg)
    2. Choise 2  (see 3.jpg)
in reply to: MateusMaciel
j'aimerais que dans mon isométrique pouvoir voir seulement l'élévation en Z et non les coordonnées X et Y et cela dans tous les isométriques
MateusMaciel
I suggest following the procedure quoted by @Anonymous
Technology Administrators
”Boost
