Message 1 of 11
AMPOWERDIM_ANG
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi community,
When i am using the command AMPOWERDIM_ANG, Autocad don´t show the dimension of the angle.
If i use the comand DIMANGULAR it works fine.
Bellow you can see the text on the command line.
Command: _ampowerdim_ang
Select arc, circle, line or [Baseline/Chain] <specify vertex>: 1 found, 1 total
Select second line:
Command: *Cancel*Do you know how to address this issue.
I´m in 2023 Autocad Version (PV 27.0.52.0),
