AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
znikające linie konstrukcyjne pod zdjęcie lub kreskowanie - disappearing construction lines under a photo or hatching
4 REPLIES 4
bezakarkonowska
226 Views, 4 Replies
Hello! I have one questions. Construction lines disappear under the photo and hatching. how to make the construction lines appear above the photos and hatching? The display order only works for existing lines, new lines are inserted again underneath. What to do? Best Regards
4 REPLIES 4
pendean
in reply to: bezakarkonowska
bezakarkonowska
in reply to: pendean
Hello! Sortents has a value of 127 and still does not work. (I write in Polish and the translator sometimes translates poorly... Thank you)
Wie Pan może jak to ustawić żeby było ok?
[translated with Google]
Do you know how to set this up so that it works ok?
Kto wie jak to ustawić? Pozdrawiam:)
Who knows how to set this up? Regards:)
