AMPOWERDIM_ANG
Fabiomcosta
AMPOWERDIM_ANG
Fabiomcosta
Hi community,
When i am using the command AMPOWERDIM_ANG, Autocad don´t show the dimension of the angle.
If i use the comand DIMANGULAR it works fine.
Bellow you can see the text on the command line.
Command: _ampowerdim_ang
Select arc, circle, line or [Baseline/Chain] <specify vertex>: 1 found, 1 total
Select second line:
Command: *Cancel*
Do you know how to address this issue.
I´m in 2023 Autocad Version (PV 27.0.52.0),
Replies (10)
TheCADnoob
Are your dimensions being created on a layer that is turned off? Turn on all your layers (as well as unfreeze) and see if your dimensions show up.
CADnoob
Fabiomcosta
Yes, I´ve already tried this,
Addiotional details that I didn´t mention before.
It happens only in the layout tabs and with the elements inside a viewport, if i draw a new line on the layout that I am using the dimension show up normally.
Patchy
This command is for Mechanical Autocad, do you have it?
TheCADnoob
I don't have access to that command at the moment. Can you select the items with the QSELECT command?
If so, can you see if there are unexpected values in the Z properties?
CADnoob
Fabiomcosta
Yes, I am using Autocad Mechanical
Bellow you can see what I am talking about,
The lines with the angle dimension i drew it on the layout space
The other ones inside of the viewport created via scale area on the model space don´t accept the ampowerdim_ang.
Other kind of dimensions like linear are working fine, and as i mentioned before the DIMANGULAR works well.
I can use the DIMANGULAR, but i would like to understand if is there a setting for make it activate/deactivate.
pendean
Community Legend
Community Legend
@Fabiomcosta wrote:
...It happens only in the layout tabs and with the elements inside a viewport...
...I´m in 2023 Autocad Version (PV 27.0.52.0)...
How are you using this command exactly? What is the feedback from your commandline (make it 5-10-15 lines tall for this exercise) when you use that command? No issues at all here using it INSIDE as well as OUTSIDE the viewport in a layout in my own drawings.
Side note: you are missing all the updates
m_latz
Can you upload the dwg from your screenshot, that I can try the exact same on my maschine ?
regards
Markus
Fabiomcosta
Command:
Command: _about
Command: *Cancel*
Command:
Command:
Select second line:
Command: *Cancel*
Hi @pendean , I´m just cliking on the icon to get an angle dimension.
The command line above is exactly the same as the first post, all the time.
I will check about the update. Thanks
Fabiomcosta
Hi @m_latz , here is a file created now an presenting the same problem. for me at least!!
Thanks for your help!!
Keshava_Murthy
Hi @Fabiomcosta,
I verified your dwg file in AutoCAD Mechanical 2023 (with update 2023.0.2) and I'm not able to reproduce the issue.
Can you please install the latest update and help to check again.
Please click ACCEPT SOLUTION if my post helps in solving your issue or answering your question.
Keshava Murthy
AutoCAD Mechanical Team
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
