AutoCAD LT Forum
Trouble with pdf exporting
5 REPLIES 5
asmith4035
287 Views, 5 Replies
I am getting back into drawing after a 12-155 year hyatus. I have never inported .pdf's t work on and then tried to export.  Everything is great on the importing, re-scaling, and working with the layers to make them reaable. BUT when I export the files thay are useless. I have a 7/8" diameter red dot I draw for rebar and it looks like a large red baketball on the pdf. the lines are to heavy and the text is unreadable.  Other than that, everything is fine! 😕 I could use some help. In the meanwhile I will continue experimenting. If I can't get the documents back to a usabkle pdf file I am wasting my time.
Thanks for your help.
alan
5 REPLIES 5
pendean
in reply to: asmith4035
We can't see what you see: can you share your source DWG file PLUS the PDF with the issues here please?
paullimapa
Have you tried plot command and select DWG To PDF.pc3
Paul Li
IT Specialist
@The Office
asmith4035
in reply to: paullimapa
We have Acrobat Pro in the office. I found that it worked great when I
plotted it to Acrobat .pdf. Thanks for your time to respond.
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
asmith4035
in reply to: pendean
Thank You, I resolved my problem by plotting it to Adobe pdf instead of
exporting the file to pdf. Thank you for your response.
alan
Forma Design Contest
Technology Administrators
