I am getting back into drawing after a 12-155 year hyatus. I have never inported .pdf's t work on and then tried to export. Everything is great on the importing, re-scaling, and working with the layers to make them reaable. BUT when I export the files thay are useless. I have a 7/8" diameter red dot I draw for rebar and it looks like a large red baketball on the pdf. the lines are to heavy and the text is unreadable. Other than that, everything is fine! 😕 I could use some help. In the meanwhile I will continue experimenting. If I can't get the documents back to a usabkle pdf file I am wasting my time.
Thanks for your help.
alan
Solved by paullimapa. Go to Solution.
Have you tried plot command and select DWG To PDF.pc3
glad to have helped...cheers!!!
