AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
caps is turned on when typing
7 REPLIES 7
Message 1 of 8
636 Views, 7 Replies
textallcaps is the only thing I could find in the help section and not even a variable in Autocad.  How do I turn off the cap lock when typing other than holding down the shift key?
7 REPLIES 7
Message 2 of 8
hwalker
Sounds like your using MTEXT
Start an MTEXT item right click in it, and make sure All CAPS is unticked
Howard Walker
Left Handed and Proud
Message 3 of 8
That worked when did they add that?
Message 4 of 8
pendean
It was added a very very long time ago: which version did you last use that it never did that?
Message 5 of 8
in reply to: pendean
I used autocad 14 lt and I guess it was never turned on and I never needed it.  Looks like  I have a lot to learn.
Message 6 of 8
Tampa
This didn't work for me. I'm using CAD 2018 LT. I don't even see an ALL CAPS option when I right click within the MT command. It hasn't always done this but it has for many weeks now.
Other suggestions???
Message 7 of 8
pendean
in reply to: Tampa
It's there for all of us, unless your setup is broken or that's not your problem at all, but something on the system level, struck CAPS LOCK or something else outside the program
Message 8 of 8
Tampa
That's it! Thanks!
Forma Design Contest
Technology Administrators
