textallcaps is the only thing I could find in the help section and not even a variable in Autocad. How do I turn off the cap lock when typing other than holding down the shift key?
Solved by Tampa. Go to Solution.
Solved by h_s_walker. Go to Solution.
Sounds like your using MTEXT
Start an MTEXT item right click in it, and make sure All CAPS is unticked
Howard Walker
Howard Walker
I used autocad 14 lt and I guess it was never turned on and I never needed it. Looks like I have a lot to learn.
This didn't work for me. I'm using CAD 2018 LT. I don't even see an ALL CAPS option when I right click within the MT command. It hasn't always done this but it has for many weeks now.
Other suggestions???
It's there for all of us, unless your setup is broken or that's not your problem at all, but something on the system level, struck CAPS LOCK or something else outside the program
That's it! Thanks!
That's it! Thanks!
