AutoCAD Forum
windows 10 32 bit
9 REPLIES 9
Message 1 of 10
13729 Views, 9 Replies
windows 10 32 bit
tell me autocad version for windows 10 32bit os
9 REPLIES 9
Message 2 of 10
cadffm
Message 3 of 10
john.vellek
Hi @Anonymous,
AutoCAD 2016 and 2017 should run in a Windows 10 32-bit as confirmed by @cadffm.  Here are the system requirements for AutoCAD.
Is there a reason that you are using a 32-bit system?
John Vellek
Message 4 of 10
DarrenP
fyi Autodesk will stop making 32 bit versions of autocad , 2019 will probably be the last version to have a 32 bit version
so if you plan to use Autocad beyond 2019 you will need to move a 64 bit os
more info here: https://knowledge.autodesk.com/search-result/caas/simplecontent/content/autocad-and-autocad-lt-32-bi...
DarrenP
Message 5 of 10
in reply to: cadffm
please how I install autocad in windows 10 32 bit operating system
Message 6 of 10
DarrenP
what version?
DarrenP
Message 7 of 10
pendean
You download and install the 32bit version of AutoCAD, if one is available: if there isn't one, you need to upgrade WIndows, there is no other fix, 32bit Windows are not good enough anymore for CAD users.
Message 8 of 10
and where to download autocad 2017?
Message 9 of 10
Grover_Puma
https://www.autodesk.com/education/free-software/autocad
HERE YOU CAN DOWNLOAD THE STUDENT VERSION FROM AUTOCAD 2018 FOR 32BITS AND 64 BITS
if this helps to solve your problem, ACCEPT SOLUTION please, this will help others find immediate answers. Thank you
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
Message 10 of 10
hyuck_jin_song
Hello @Anonymous
If you have an available subscription license or maintenance plan license, you can request Autodesk Client Services team for AutoCAD 2017 download link.
Please contact to Autodesk Client Services team first here
Thank you.
HyuckJin, Song
Sr Technical Support Specialist
Customer Technical Success APAC
Forma Design Contest
