tell me autocad version for windows 10 32bit os
Solved by DarrenP. Go to Solution.
Solved by cadffm. Go to Solution.
2016SP1 and 2017, if i read correct https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/System...
Sebastian
Hi @Anonymous,
AutoCAD 2016 and 2017 should run in a Windows 10 32-bit as confirmed by @cadffm. Here are the system requirements for AutoCAD.
Is there a reason that you are using a 32-bit system?
fyi Autodesk will stop making 32 bit versions of autocad , 2019 will probably be the last version to have a 32 bit version
so if you plan to use Autocad beyond 2019 you will need to move a 64 bit os
more info here: https://knowledge.autodesk.com/search-result/caas/simplecontent/content/autocad-and-autocad-lt-32-bi...
DarrenP
what version?
DarrenP
https://www.autodesk.com/education/free-software/autocad
HERE YOU CAN DOWNLOAD THE STUDENT VERSION FROM AUTOCAD 2018 FOR 32BITS AND 64 BITS
if this helps to solve your problem, ACCEPT SOLUTION please, this will help others find immediate answers. Thank you
Hello @Anonymous
If you have an available subscription license or maintenance plan license, you can request Autodesk Client Services team for AutoCAD 2017 download link.
Please contact to Autodesk Client Services team first here
Thank you.
