SHIFT KEY NOT WORKING
Message 1 of 52
Shift key is not working for for me while using for deselect & ortho mode.
Can anyone help me plzz... I tried PICKADD & PICKFIRST.
Smiley Sad
Replies (51)
Message 21 of 52
pendean
Community Legend
Community Legend
Works fine here in LT2023.0.1 for us.
1) There is about a 1-second delay before it kicks in: are you waiting long enough?
2) F8 to toggle ORTHO on/off after you start a command like MOVE not working too?
3) At the command line type TEMPOVERRIDES. Change the value to 1. Does that fix it?
Do you have the 2023.0.1 update installed? it is required regardless of your issue. ABOUT command will confirm what you have installed. Get it done if not.
Message 22 of 52
janetkozadesign
Observer
Observer
Thank you! The tempoverrides worked this time. Not sure why it didn't
work before - I must have messed something up! Thanks again!
Message 23 of 52
Tiziano_B
Works! 10x man! You saved me!
Message 24 of 52
braedeny
I just ran into this issue in Autocad LT 2023. Whenever I tried shift-selecting something the command line just repeated the text <cycle ON> <cycle OFF> every time I tried clicking on something. I fixed the issue by restarting my PC. I havn't had the issue since yesterday, and I still don't know what caused it, but the restart seemed to be the solution.
Message 25 of 52
rickmmock
This is exactly the solution!
I wonder how this setting changed on it's own?
Silly AutoCAD.
Message 26 of 52
jasonscottburton
Community Visitor
Community Visitor
TEMPOVERRIDES command, change value to 1 in order to use shift as an override hotkey.  My Autocad LT for Mac 2023 suddenly switched the value to zero on its own.
Message 27 of 52
aarmaza49DMX
if you have geomap image, then shift will not work. Try removing the geomap image if this is the case.
Message 28 of 52
aarmaza49DMX
Message 29 of 52
saquib_ansari
Observer
Observer
THIS COMMEND IS WORKED.
Message 30 of 52
janetkozadesign
Observer
Observer
I'm still struggling with this!  My Shift command (to draw straight line) does not work in autocad LT. Tried tempoverrides.. still nothing
Message 31 of 52
pendean
Community Legend
Community Legend
There is something like 1-second or so pause before it kicks in: perhaps you're not waiting long enough?
And when you repost, tell everyone your exact LT year version and your Windows version please.
Message 32 of 52
maiko_sousa
Bingo! I installed Raster Tools today and after unchecking "Shift + left click image select", the problem was resolved.
Message 33 of 52
sampatsMT4V3
Community Visitor
Community Visitor
USE CMD =  TEMPOVERIDES
Message 34 of 52
infoT7QWV
Observer
Observer
It’s working after temoveride  —
‘thx .
Message 35 of 52
infoT7QWV
Observer
Observer
Working thx
Message 36 of 52
huddarrutuja248
Community Visitor
Community Visitor
my shift key is not working for deselecting objects. can you help me please , I tried every options like PICKADD,PICKFIRST,TAMPOVERIDES, etc
Message 37 of 52
pendean
Community Legend
Community Legend
Restart your PC yet? Always something to try first.
TEMPOVERRIDES is the variable, no A in it, setting is 1.
or this highlighted tip if you installed RASTERDESIGN
https://forums.autodesk.com/t5/autocad-forum/shift-key-not-working/td-p/6784028#:~:text=RASTER%20TOO...
Message 38 of 52
icollazoFSX7K
Community Visitor
Community Visitor
This worked! Thanks! 😃
Message 39 of 52
cmitchellBK9VD
Observer
Observer
I was having the same problem. I found that when I used shift to deselect, it was actually adding my Xref image (even though the layer it was on was frozen and not showing up). I moved the image out of the viewport while in model space, and the shift deselect worked again when I went back into my viewport.
Hope that helps some of you
Message 40 of 52
andrejs_kononcuks
Observer
Observer
Hi all
I have tried all mentioned options before with TEMPOVERRIDES (1), RASTER TOOLS>INSERT AND WRITE (both drop downs) brings dialog box: USER PREFERENCES>under Mouse settings uncheck "Shift + left click image select". And nothing helped. Drives me crazy not to have this toggle ortho on/off by holding down shift key. I am using AutoCAD 2024, that is run by Lenovo ThinkBook 16p G5 IRX on Win11 Pro. If there is some other advice how to resolve this, please let me know.
