Diesel adding an undesired blankspace to string
xiandavis
xiandavis
Our company uses the following sheet naming convention:
Dxx detailSheetName
where Dxx is a detail number from D1 to D99.
The intent of the below Diesel expression is to pull the Detail number from the Layout tab name for either a single digit or double digit following the D and update the field inside the attribute.
Running the below code on Layout tab "P2 WALKWAY PAD LAYOUT" displays the desired "P2", but with a leading space " P2".
Running the below code on Layout tab "P10 ERRC CONDUIT PENETRATION" displays the desired "P10", but with a leading space " P10".
$(if, $(eq, $(substr, $(getvar, ctab),4,1), " "), $(substr, $(getvar, ctab),2,2), $(substr, $(getvar, ctab),2,3))
Apparently there is an invisible/escape character in the string, as I would expect the below numbers would have produced the desired results:
$(if, $(eq, $(substr, $(getvar, ctab),3,1), " "), $(substr, $(getvar, ctab),1,2), $(substr, $(getvar, ctab),1,3))
Any suggestions on how to eliminate the leading blank space character, or at least know where it is coming from? I came up with the syntax after looking at several Diesel examples in the forums.
Thank you.
cadffm
remove all the unneeded blanks in your Dieselcode!
Means all, except the one between " "
Try it again..
Sebastian
xiandavis
Thanks!
