AutoCAD Forum
SHIFT KEY NOT WORKING
32 REPLIES 32
Message 1 of 33
34711 Views, 32 Replies
Shift key is not working for for me while using for deselect & ortho mode.
Can anyone help me plzz... I tried PICKADD & PICKFIRST.
Smiley Sad
32 REPLIES 32
Message 2 of 33
imadHabash
Hi and Welcome to AutoDesk Forum,
You can add objects to, or remove objects from the selection set by pressing SHIFT while selecting,also make your PICKADD=2.
Note:
  • you can type R then [enter] to change selection mode to remove. Then you can type A then [enter] to switch back to add selection.
  •  if you have Raster Design and or AutoCAD Map?
    If so, run the commands MAPIOPTIONS ) or IOPTIONS . Look for a setting labeled “Shift+Left click image select”
    Uncheck this setting and see if it's fixed.
Imad Habash
Message 3 of 33
Emmsleys
Hi @Anonymous!
Can you verify that verify the PICKADD variable, is it set to 2 or is it set to another value?
Sarah Emmsley
Technical Support Specialist
Message 4 of 33
Use the options command.
Go to selection tabs.
The Use Shift to add selection box should be unchecked.
Hope it helps
Message 5 of 33
in reply to: Emmsleys
I tried that. but not worked for me.
TEMPOVERRIDES command solved the problem..
Smiley LOL
Message 6 of 33
HI I TRIED ALL THE ABOVE AND SHIFT COMMAND STILL NOT WORKING ..ANY HELP!?
Message 7 of 33
imadHabash
would you please make a new detailed post for your issue to get more help from others ?
Imad Habash
Message 8 of 33
For me TEMPOVERRIDES command solved the problem..
Smiley LOL
Message 9 of 33
I tried TEMPOVERRIDES still not working for me any other solutions !!! I have AUTOCAD 2016
Message 10 of 33
rataylor
shift key not working to unselect. why?
Message 11 of 33
in reply to: rataylor
Try TEMPOVERRIDES command.
Message 12 of 33
rataylor
TEMPOVERRIDES doesn't work with any value(0 or 1) but a google search fixed it: RASTER TOOLS>INSERT AND WRITE(both drop downs) brings dialog box: USER PREFERENCES>under Mouse settings uncheck "Shift + left click image select".
Another problem I'm having with my new laptop and 2018 Autocad(educational version) my Right click customizations settings are like every version I have ever used: right click enters and repeats command. Now I have right click twice SOMETIMES. Sometimes only once. When it doesn't work correctly the cursor just disappears until I move the mouse. Right clicking again enters the command what is up with that. Thanks rt.
Message 13 of 33
Restart your autoCAD and computer. It works again!
Message 14 of 33
use IOPTION commond the click USER PREFERENCE and unselect SHIFT +LEFT CLIKC IMAGE selection Thats it...Now your key will be working
Message 15 of 33
rataylor
my autocad 2015 (educational version) has no "IOPTION" command.
Message 16 of 33
you can use option command also
Message 17 of 33
I was suffering like you, the solution is >> first choose the command that you want to do ( for example Move) then select the object, and after that press Shift.
Message 18 of 33
RobDraw
That solution is not appropriate for this issue.
Rob
Message 19 of 33
sharpl
It worked as "0" in 2021, thank you!
Message 20 of 33
janetkozadesign
I've been having trouble with this - my select object, move, shift (so that it goes vertical or horizontal) isn't working.  The shift key is no longer making this happen.  I've tried all the above suggestions - just downloaded my new 2023 autocad LT and its still not working.  Help please!
Forma Design Contest
AutoCAD Beta
