AutoCAD Forum
*NO LAYERS
5 REPLIES 5
andrew.wheaton
1779 Views, 5 Replies
*NO LAYERS
Can anyone help me, what is making my Layer Manager box come up *No Layer. Image attached.
Is there an easy fix? All I have in my drawing is a 2D Topo and some mapping in DWG.
john.vellek has embedded your image(s) for clarity
5 REPLIES 5
HI @andrew.wheaton,
Do you have some sort of layer filter applied? Have you run Audit to see if any drawing errors are reported?
Please tell me the exact version of AutoCAD you are running.
Can you share your file with me so I can see if the same thing shows up on my side?
John Vellek
pendean
in reply to: andrew.wheaton
Restart your PC and try again.
cadffm
I saw it the first time ago (only screenshot), it was a corrupt non-autodesk file.
Open by RECOVER solved the problem.
RECOVERALL if you have dwg XREFs.
Sebastian
andrew.wheaton
in reply to: pendean
Issue resolved upon restart.
Use wblock
Forma Design Contest
AutoCAD Beta
