AutoCAD Forum
*NO LAYERS
5 REPLIES 5
andrew.wheaton
1918 Views, 5 Replies
*NO LAYERS
andrew.wheaton
Can anyone help me, what is making my Layer Manager box come up *No Layer. Image attached.
Is there an easy fix? All I have in my drawing is a 2D Topo and some mapping in DWG.
john.vellek has embedded your image(s) for clarity
*NO LAYERS
5 REPLIES 5
john.vellek
HI @andrew.wheaton,
Do you have some sort of layer filter applied? Have you run Audit to see if any drawing errors are reported?
Please tell me the exact version of AutoCAD you are running.
Can you share your file with me so I can see if the same thing shows up on my side?
John Vellek
HI @andrew.wheaton,
John Vellek
pendean
in reply to: andrew.wheaton
pendean
Community Legend
Community Legend
Restart your PC and try again.
cadffm
cadffm
I saw it the first time ago (only screenshot), it was a corrupt non-autodesk file.
Open by RECOVER solved the problem.
RECOVERALL if you have dwg XREFs.
Sebastian
Sebastian
andrew.wheaton
in reply to: pendean
andrew.wheaton
Issue resolved upon restart.
gerardobarria
Community Visitor
Community Visitor
Use wblock
Use wblock
AutoCAD Inside the Factory
