Can anyone help me, what is making my Layer Manager box come up *No Layer. Image attached.
Is there an easy fix? All I have in my drawing is a 2D Topo and some mapping in DWG.
john.vellek has embedded your image(s) for clarity
Solved by pendean. Go to Solution.
HI @andrew.wheaton,
Do you have some sort of layer filter applied? Have you run Audit to see if any drawing errors are reported?
Please tell me the exact version of AutoCAD you are running.
Can you share your file with me so I can see if the same thing shows up on my side?
I saw it the first time ago (only screenshot), it was a corrupt non-autodesk file.
Open by RECOVER solved the problem.
RECOVERALL if you have dwg XREFs.
Sebastian
