AutoCAD Forum
Is there a way of saving selected objects isolation state?
10 REPLIES 10
Message 1 of 11
efergusson
2967 Views, 10 Replies
I would like to be able to save or store a set of isolated objects. Layer states are no good for this exercise.
Efraim
10 REPLIES 10
Message 2 of 11
pendean
in reply to: efergusson
Can you elaborate with a detailed example please?
Message 3 of 11
efergusson
I have a large model & wish to only display specific objects using object isolation. The routine is great but when I show all objects I have to reselect which is really time consuming.
I would like to be able have access to specific selection sets in order to isolate on demand.
Message 4 of 11
nestly2
One possibility might be to include all the objects in a GROUP
For normal use, just turn Groups OFF, and work normally, but when/if you need to isolate all those objects, turn Groups ON, and select any of the objects in the group to select the entire group, then use ISOLATEOBJECTS as you normally would.  Once the "group" is Isolated, just turn Groups OFF again.
When using the Ribbon, Groups are very easy to work with, it takes a single click to create a group of all the selected objects, and it only takes one click to turn groups On/Off
Message 5 of 11
efergusson
in reply to: nestly2
Thanks Nestly2
thats what I'm currently doing. Can you have the same object in multiple groups?
Message 6 of 11
ВeekeeCZ
How about save a current view inc. layer state.
_view command
Message 7 of 11
efergusson
in reply to: ВeekeeCZ
Not good as only want specific objects. not all the objects on the layer.
Message 8 of 11
nestly2
@efergusson wrote:
..... Can you have the same object in multiple groups?
I did a quick test, and it appears you can.
Message 10 of 11
command line <OBJECTISOLATIONMODE> change the value to 1
Message 11 of 11
TomBeauford
Objects can be members of more than one group. Selecting an object that belongs to multiple groups selects all groups to which that object belongs.
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-C20C24AD-81F5-4E4A-A414-B1A2BC71E041
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
AutoCAD Inside the Factory
