Is there a way of saving selected objects isolation state?
efergusson
efergusson
I would like to be able to save or store a set of isolated objects. Layer states are no good for this exercise.
Efraim
0 Me gusta
Responder
Soluciones aceptadas (1)
3.291 Vistas
10 Respuestas
Respuestas (10)
pendean
Community Legend
Community Legend
Can you elaborate with a detailed example please?
0 Me gusta
efergusson
I have a large model & wish to only display specific objects using object isolation. The routine is great but when I show all objects I have to reselect which is really time consuming.
I would like to be able have access to specific selection sets in order to isolate on demand.
0 Me gusta
nestly2
One possibility might be to include all the objects in a GROUP
For normal use, just turn Groups OFF, and work normally, but when/if you need to isolate all those objects, turn Groups ON, and select any of the objects in the group to select the entire group, then use ISOLATEOBJECTS as you normally would.  Once the "group" is Isolated, just turn Groups OFF again.
When using the Ribbon, Groups are very easy to work with, it takes a single click to create a group of all the selected objects, and it only takes one click to turn groups On/Off
efergusson
Thanks Nestly2
thats what I'm currently doing. Can you have the same object in multiple groups?
0 Me gusta
ВeekeeCZ
How about save a current view inc. layer state.
_view command
0 Me gusta
efergusson
Not good as only want specific objects. not all the objects on the layer.
0 Me gusta
nestly2
Solución aceptada
@efergusson wrote:
..... Can you have the same object in multiple groups?
I did a quick test, and it appears you can.
fredlinjayanasco
command line <OBJECTISOLATIONMODE> change the value to 1
TomBeauford
Objects can be members of more than one group. Selecting an object that belongs to multiple groups selects all groups to which that object belongs.
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-C20C24AD-81F5-4E4A-A414-B1A2BC71E041
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
0 Me gusta
