02-03-2015
01:05 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-03-2015
01:05 PM
One possibility might be to include all the objects in a GROUP
For normal use, just turn Groups OFF, and work normally, but when/if you need to isolate all those objects, turn Groups ON, and select any of the objects in the group to select the entire group, then use ISOLATEOBJECTS as you normally would. Once the "group" is Isolated, just turn Groups OFF again.
When using the Ribbon, Groups are very easy to work with, it takes a single click to create a group of all the selected objects, and it only takes one click to turn groups On/Off
