AutoCAD Forum
How to turn on and off command line for version 2004
21 REPLIES 21
Message 1 of 22
1854 Views, 21 Replies
I'm using auto version 2004 how do I turn on and off my command line?
21 REPLIES 21
Message 2 of 22
lim.wendy
Hi @Anonymous,
Welcome to the forum and thanks for posting.
Sorry, do you mean AutoCAD version 2004?
See this old post.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
Message 3 of 22
cadffm
What a crazy idea (no matter in which version) to want to turn off the only really meaningful communication source in the block field with the program.
>"How to turn on and off command line for version 2004"
Hard to remember but i though you can't. Commands COMMANDLINE/COMMANDLINECLOSE started a bit later with v2006.
The only thing is to use a tool that moves the commandline(CMDL) to outside of the visible screen
and back to the the visible screen area. [I doesn't support to turn the CMDL off, therefore you have to look for a tool yourself if you want to]
Keep CMFL always on with 4 lines visible to see all feedback from AutoCAD commands.
Sebastian
Message 4 of 22
hak_vz
For a start try key combination <CTRL> + <9>
Miljenko Hatlak
Message 5 of 22
cadffm
in reply to: hak_vz
CTRL+9 ist toggling COMMANDLINE&COMMANDLINECLOSE(in your Version), so it isn't available.
Sebastian
Message 6 of 22
in reply to: cadffm
Betreff, Thanks for responding. I agree with you about having the command
line on. My co-worker used my machane and lost my command line. I have been
running the text window on my 2nd monitor.
I changed my screen resolution to see if it was just moved out of sight,
nothing. I think somehow it was turned off and I want to turn it on.
Message 7 of 22
in reply to: lim.wendy
Yes the company I work for doesn't upgrade. My coworker used my machine and
somehow turned off or lost my command line.
Message 8 of 22
cadffm
>"I think somehow it was turned off and I want to turn it on."
No, it is
1. outside your visible screen
 OR
2. tiny/hidden
    Often it is hidden under the Taskbar! (turn Taskbar to autohide to see what is behind)
or
3. You already tried this
   Change the resolution
4 - Best way - we waiting for some one who has also ACAD pre2006 version or just one who can remember well how it was in this version.
  If the position was part of the Profil: Go to OPTIONS Profile, Export the current Profile
  and share the *.ARG file (as ZIP) - we can reset the position there IF the information is stored there.
At last: Change your Profile OPTIONS PROFILE
or start with a new one: Start parameter /p "NewProfile"
Sebastian
Message 9 of 22
Patchy
in reply to: cadffm
I agree that the command line is off the screen, not lost.
Options and reset it in the profile (the 1st thing to try.)
Message 10 of 22
cadffm
@Anonymous
IF the position is saved in Profile, use InList first, then Profile [Reset]
Or EXPORT first,
if RESET works, we can edit your *.arg Profile - then you have your profile like before, just with the CMDL visible
Sebastian
Message 11 of 22
in reply to: cadffm
Betreff, I hid the taskbar, moved it to the top and right side, nothing. I
went to a coworker and exported his ARG file and imported to mine set as
current and still no change.
Message 12 of 22
in reply to: cadffm
Tried reset nothing changed
Message 13 of 22
pendean
Message 14 of 22
cadffm
in reply to: pendean
The same.Both commands not available in 2004 and also the CUI command, all three started in 2006.
@john.uhden sorry for belling - Where is the (floating) commandline position stored in 200-2005 ?
Sebastian
Message 15 of 22
Thanks, I tried both but 2004 does not have that command.
Message 16 of 22
cadffm
Hi @Anonymous
It pulled out my lost laptop,
installed a 2005 version
and now i can help you:
press [ESC]
type in:
_line<enter hit>
follow the key combinations
[ALT]+[SPACE]
[M]
In this second your cursor disappear, right?
and no dialog/menu appears?
Then:
<Now, hit one arrow Key, for example arrow-LEFT>
Now you can move the mouse (without to press a button),
move around until you see the commandline & your cursor.
Sebastian
Message 17 of 22
in reply to: cadffm
You are a genius and it worked like a charm thank you very much.
Message 18 of 22
RobDraw
On a side note, there was some talk a few years ago about getting rid of the command line.
Rob
Message 19 of 22
john.uhden
in reply to: cadffm
@cadffm :
I don't know offhand. I am at my wife's laptop. I will try to remember to
find out if and where it is. I am no longer working for the 2004
employer. I have only 2002 at home and 2020 at work. I have the 2004 CDs,
but have lost the authorization code. I got it when I was a registered
developer, but since I haven't paid my dues in years, I doubt that Denis
Cadu would give me the code again. Hmm, maybe I'll just ask anyway.
We have learned that people around my neighborhood have planned out how to
handle the Halloween trick-or-treaters in light of the pandemic. One guy
said he was going to shoot candies at the kids with a slingshot. Another
said he was going to eat all the candy himself, just like every other year.
John F. Uhden
Message 20 of 22
cadffm
in reply to: john.uhden
Thank you John, it's solved.
After running cross each room, each corner, i found an old Laptop.
I run further to find a power adapter, done.
Remember the admin password,
insert 2005 CD,
Install, waaaaaaaaaaiiiiting for a long time
Program start, undock the CMDL and
1. make sure it is really not stored in the profile (right)
2. Test [ALT]+[SPACE] Menu... Jackpot. Floated CMDL acts like other Dialogs in these old versions
(2004 or 2002 is the same for this question, i think the CMD was up to 2005 the same, or up to 2008?)
Sebastian
Forma Design Contest
AutoCAD Beta
