How to turn on and off command line for version 2004
No aplicable
I'm using auto version 2004 how do I turn on and off my command line?
0 Me gusta
Responder
Soluciones aceptadas (1)
2.442 Vistas
21 Respuestas
Respuestas (21)
lim.wendy
Hi @Anonymous,
Welcome to the forum and thanks for posting.
Sorry, do you mean AutoCAD version 2004?
See this old post.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
0 Me gusta
cadffm
What a crazy idea (no matter in which version) to want to turn off the only really meaningful communication source in the block field with the program.
>"How to turn on and off command line for version 2004"
Hard to remember but i though you can't. Commands COMMANDLINE/COMMANDLINECLOSE started a bit later with v2006.
The only thing is to use a tool that moves the commandline(CMDL) to outside of the visible screen
and back to the the visible screen area. [I doesn't support to turn the CMDL off, therefore you have to look for a tool yourself if you want to]
Keep CMFL always on with 4 lines visible to see all feedback from AutoCAD commands.
Sebastian
0 Me gusta
hak_vz
For a start try key combination <CTRL> + <9>
Miljenko Hatlak
0 Me gusta
cadffm
CTRL+9 ist toggling COMMANDLINE&COMMANDLINECLOSE(in your Version), so it isn't available.
Sebastian
0 Me gusta
No aplicable
Betreff, Thanks for responding. I agree with you about having the command
line on. My co-worker used my machane and lost my command line. I have been
running the text window on my 2nd monitor.
I changed my screen resolution to see if it was just moved out of sight,
nothing. I think somehow it was turned off and I want to turn it on.
0 Me gusta
No aplicable
Yes the company I work for doesn't upgrade. My coworker used my machine and
somehow turned off or lost my command line.
0 Me gusta
cadffm
>"I think somehow it was turned off and I want to turn it on."
No, it is
1. outside your visible screen
 OR
2. tiny/hidden
    Often it is hidden under the Taskbar! (turn Taskbar to autohide to see what is behind)
or
3. You already tried this
   Change the resolution
4 - Best way - we waiting for some one who has also ACAD pre2006 version or just one who can remember well how it was in this version.
  If the position was part of the Profil: Go to OPTIONS Profile, Export the current Profile
  and share the *.ARG file (as ZIP) - we can reset the position there IF the information is stored there.
At last: Change your Profile OPTIONS PROFILE
or start with a new one: Start parameter /p "NewProfile"
Sebastian
0 Me gusta
Patchy
I agree that the command line is off the screen, not lost.
Options and reset it in the profile (the 1st thing to try.)
0 Me gusta
cadffm
@Anonymous
IF the position is saved in Profile, use InList first, then Profile [Reset]
Or EXPORT first,
if RESET works, we can edit your *.arg Profile - then you have your profile like before, just with the CMDL visible
Sebastian
0 Me gusta
No aplicable
Betreff, I hid the taskbar, moved it to the top and right side, nothing. I
went to a coworker and exported his ARG file and imported to mine set as
current and still no change.
0 Me gusta
No aplicable
Tried reset nothing changed
0 Me gusta
pendean
Community Legend
Community Legend
0 Me gusta
cadffm
The same.Both commands not available in 2004 and also the CUI command, all three started in 2006.
@john.uhden sorry for belling - Where is the (floating) commandline position stored in 200-2005 ?
Sebastian
0 Me gusta
No aplicable
Thanks, I tried both but 2004 does not have that command.
0 Me gusta
cadffm
Solución aceptada
Hi @Anonymous
It pulled out my lost laptop,
installed a 2005 version
and now i can help you:
press [ESC]
type in:
_line<enter hit>
follow the key combinations
[ALT]+[SPACE]
[M]
In this second your cursor disappear, right?
and no dialog/menu appears?
Then:
<Now, hit one arrow Key, for example arrow-LEFT>
Now you can move the mouse (without to press a button),
move around until you see the commandline & your cursor.
Sebastian
No aplicable
You are a genius and it worked like a charm thank you very much.
0 Me gusta
RobDraw
On a side note, there was some talk a few years ago about getting rid of the command line.
Rob
0 Me gusta
john.uhden
@cadffm :
I don't know offhand. I am at my wife's laptop. I will try to remember to
find out if and where it is. I am no longer working for the 2004
employer. I have only 2002 at home and 2020 at work. I have the 2004 CDs,
but have lost the authorization code. I got it when I was a registered
developer, but since I haven't paid my dues in years, I doubt that Denis
Cadu would give me the code again. Hmm, maybe I'll just ask anyway.
We have learned that people around my neighborhood have planned out how to
handle the Halloween trick-or-treaters in light of the pandemic. One guy
said he was going to shoot candies at the kids with a slingshot. Another
said he was going to eat all the candy himself, just like every other year.
John F. Uhden
0 Me gusta
cadffm
Thank you John, it's solved.
After running cross each room, each corner, i found an old Laptop.
I run further to find a power adapter, done.
Remember the admin password,
insert 2005 CD,
Install, waaaaaaaaaaiiiiting for a long time
Program start, undock the CMDL and
1. make sure it is really not stored in the profile (right)
2. Test [ALT]+[SPACE] Menu... Jackpot. Floated CMDL acts like other Dialogs in these old versions
(2004 or 2002 is the same for this question, i think the CMD was up to 2005 the same, or up to 2008?)
Sebastian
0 Me gusta
