I'm using AutoCAD 2014 I'm facing issue in exporting dgn files. I have kept drawing in layout space from model space and I need to export dgn files from layout space is it possible to do that. Please help me for solving this query.
Basava
Enter Command DGNEXPORT and save
Jayhar.M.J
As per your advice I used Dgnexport and gave path to save for dgn file. I used v8 dgn for exporting after that I opened it in AutoCad for checking it's showing blank page no drawing content inside.
Basava
I have kept the drawing in mm units but after exporting to dgn will they change the units?
Because after importing back to AutoCAD all units were changed.
Because after importing back to AutoCAD all units were changed.>>>>
Specify Seed file in Export DGN Settings. select sub unit Millimeters
Jayhar.M.J
Internal Error message importing DGN file into AutoCAD or open in Micro station ???
Export DWG files to the V7 DGN drawing file formats
http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-55025BD6-C459-4049-8FBD-1CDA130E4D47
