AutoCAD Forum
Active Document is modified or not?
4 REPLIES 4
325 Views, 4 Replies
Is there any possibility to identify that active saved document is modified or not?
Kindly suggest some solution for this.
kavitha J
kavitha J
4 REPLIES 4
chriscowgill7373
chriscowgill7373
Can you provide any additional information?  In the drawing window if you have drawing tabs turned on, you can see a little * next to the file name if it has been modified.  However, AutoCAD considers panning or zooming as modifying the drawing.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
ed57gmc
ed57gmc
The DBMOD sysvar will be greater than 0.
Ed
How to post your code.
Ed
in reply to: chriscowgill7373
Thanks for the reply, but I'm sorry! I forgot to mention that I want to find though API not through a manual process. Is there any API to find that active saved document is modified or not?
in reply to: ed57gmc
Thanks @ed57gmc .It's working.
AutoCAD Inside the Factory
