AutoCAD Forum
Export to DGN file
12 REPLIES 12
Message 1 of 13
805 Views, 12 Replies
Export to DGN file
I'm using AutoCAD 2014 I'm facing issue in exporting dgn files. I have kept drawing in layout space from model space and I need to export dgn files from layout space is it possible to do that. Please help me for solving this query.
Basava
Export to DGN file
Basava
12 REPLIES 12
Message 2 of 13
jayhar
jayhar
Enter Command DGNEXPORT and save
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Jayhar.M.J
Message 3 of 13
in reply to: jayhar
As per your advice I used Dgnexport and gave path to save for dgn file. I used v8 dgn for exporting after that I opened it in AutoCad for checking it's showing blank page no drawing content inside.
Basava
Basava
Message 4 of 13
in reply to: jayhar
Actually I'm exporting from layout space not from model space
Message 5 of 13
I have kept the drawing in mm units but after exporting to dgn will they change the units?
Because after importing back to AutoCAD all units were changed.
Message 6 of 13
jayhar
jayhar
Because after importing back to AutoCAD all units were changed.>>>>
Specify Seed file in Export DGN Settings. select sub unit Millimeters
Jayhar.M.J
Jayhar.M.J
Message 7 of 13
in reply to: jayhar
V8-metric-seed 3d .dgn and sub units millimeters.
Message 8 of 13
jayhar
jayhar
Internal Error message importing DGN file into AutoCAD or open in Micro station ???
Message 9 of 13
in reply to: jayhar
Seed file snapSeed file snap
Message 10 of 13
in reply to: jayhar
Internal error in AutoCad
Message 11 of 13
jayhar
jayhar
Export DWG files to the V7 DGN drawing file formats
http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-55025BD6-C459-4049-8FBD-1CDA130E4D47
Message 12 of 13
in reply to: jayhar
Let me check
Let me check
Message 13 of 13
in reply to: jayhar
Actually I need V8 instead of V7.
AutoCAD Inside the Factory
