Export to DGN file
Export to DGN file
Message 1 of 13
Export to DGN file
I'm using AutoCAD 2014 I'm facing issue in exporting dgn files. I have kept drawing in layout space from model space and I need to export dgn files from layout space is it possible to do that. Please help me for solving this query.
Basava
Replies (12)
Message 2 of 13
jayhar
Enter Command DGNEXPORT and save
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Message 3 of 13
As per your advice I used Dgnexport and gave path to save for dgn file. I used v8 dgn for exporting after that I opened it in AutoCad for checking it's showing blank page no drawing content inside.
Basava
Message 4 of 13
Actually I'm exporting from layout space not from model space
Message 5 of 13
I have kept the drawing in mm units but after exporting to dgn will they change the units?
Because after importing back to AutoCAD all units were changed.
Message 6 of 13
jayhar
Because after importing back to AutoCAD all units were changed.>>>>
Specify Seed file in Export DGN Settings. select sub unit Millimeters
Jayhar.M.J
Message 7 of 13
V8-metric-seed 3d .dgn and sub units millimeters.
Message 8 of 13
jayhar
Internal Error message importing DGN file into AutoCAD or open in Micro station ???
Message 9 of 13
Seed file snapSeed file snap
Message 10 of 13
Internal error in AutoCad
Message 11 of 13
jayhar
Export DWG files to the V7 DGN drawing file formats
http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-55025BD6-C459-4049-8FBD-1CDA130E4D47
Message 12 of 13
Let me check
Message 13 of 13
Actually I need V8 instead of V7.
