AutoCAD Forum
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
ever changing cad drawings
40 REPLIES 40
Message 1 of 41
960 Views, 40 Replies
why does my CAD drawings keep changing as i continue to work ? , I have noted many times the minor alterations I do seem to be undone , this is truly slowing me down
40 REPLIES 40
Message 2 of 41
TheCADnoob
Is this a shared file? is it on a network drive? What method are you using to save your drawing?
CADnoob
Message 3 of 41
in reply to: TheCADnoob
well i do not know if this is  a shared file , but yes i am connected to the office network
Message 4 of 41
RobDraw
This is probably not an AutoCAD issue.
It's easy enough to find out who saved the file last and when to find out where the problem lies.
Rob
Message 5 of 41
dgorsman
Are pieces moving/rotating along with others, even though you aren't selecting them?  Is automatically infer constraints turned on?
Message 6 of 41
wispoxy
If you're working with XREFs, bind them.
Message 7 of 41
in reply to: RobDraw
A PEBKAC error maybe?  šŸ™‚
Message 8 of 41
RobDraw
in reply to: wispoxy
You should be sure of your drawing environment before doing this as it is probably not a good idea, especially if they are changing. That is unless you have an unusual situation.
Rob
Message 9 of 41
hmm , even the windows or inbox suddenly close or pop up , could it be some sort of virus
Message 10 of 41
wispoxy
Check your XREFs.
Message 11 of 41
RobDraw
@Anonymous wrote:
Check your XREFs.
For what? We don't even know if there are any present.
Rob
Message 12 of 41
mine keep changing too but I blame it on the architects keep changing their minds.
Message 13 of 41
wispoxy
Type command XREF to see if there are any present.
Message 14 of 41
RobDraw
How are you getting XREFs from the OPs description?
Rob
Message 15 of 41
pendean
>>>...minor alterations I do seem to be undone ...<<<
>>>...well i do not know if this is a shared file , but yes i am connected to the office network...<<<
>>>...hmm , even the windows or inbox suddenly close or pop up...<<<
OP can't seem to answer any questions with much detail so everyone is doing the nxt best thing and throwing out guesses. Each is as valid as any other guess until the OP is able to answer questions intelligibly.
Message 16 of 41
RobDraw
in reply to: pendean
That's a matter of opinion. If alterations are being done to the file, then XREF is probably not the issue.
Rob
Message 17 of 41
pendean
>>>...XREF is probably not the issue...<<<
We don't know that yet from the OP.
Message 18 of 41
wispoxy
I use xrefs on a shared network and I intentionally change them if needed. Then all of our projects change at the same time. Don't need it said.
Message 19 of 41
RobDraw
This statement makes me think that the minor alterations are not to XREFs, even if they are present. But, I guess I might be being presumptive.
Rob
Message 20 of 41
This is truly annoying
Forma Design Contest
AutoCAD Beta
