why does my CAD drawings keep changing as i continue to work ? , I have noted many times the minor alterations I do seem to be undone , this is truly slowing me down
Is this a shared file? is it on a network drive? What method are you using to save your drawing?
CADnoob
well i do not know if this is a shared file , but yes i am connected to the office network
This is probably not an AutoCAD issue.
It's easy enough to find out who saved the file last and when to find out where the problem lies.
Are pieces moving/rotating along with others, even though you aren't selecting them? Is automatically infer constraints turned on?
@Anonymous wrote:
If you're working with XREFs, bind them.
You should be sure of your drawing environment before doing this as it is probably not a good idea, especially if they are changing. That is unless you have an unusual situation.
@Anonymous wrote:
Check your XREFs.
For what? We don't even know if there are any present.
@Anonymous wrote:
Type command XREF to see if there are any present.
How are you getting XREFs from the OPs description?
@Anonymous wrote:why does my CAD drawings keep changing as i continue to work ? , I have noted many times the minor alterations I do seem to be undone , this is truly slowing me down
@pendean wrote:
>>>...minor alterations I do seem to be undone ...<<<
>>>...well i do not know if this is a shared file , but yes i am connected to the office network...<<<
>>>...hmm , even the windows or inbox suddenly close or pop up...<<<
OP can't seem to answer any questions with much detail so everyone is doing the nxt best thing and throwing out guesses. Each is as valid as any other guess until the OP is able to answer questions intelligibly.
That's a matter of opinion. If alterations are being done to the file, then XREF is probably not the issue.
@Anonymous wrote:I have noted many times the minor alterations I do seem to be undone
This statement makes me think that the minor alterations are not to XREFs, even if they are present. But, I guess I might be being presumptive.
