Drawing is somehow Xrefed into itself
Message 1 of 65
I am currently working on a drawing and just relaized that it is somehow Xrefed into itself and I am unable to detach it.  Any thoughts?  Thanks in advance.
S.Clancy
Replies (64)
Message 61 of 65
Alfred.NESWADBA
run command _PURGE, then you can detach the XREF, so I guess there is a block defined, into which the XRef is built in.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 62 of 65
Alfred.NESWADBA
and the block, which holds the XRef is: "Manufactoring".
If you purge that blockdefinition then detaching of the XRef is possible.
BTW: you have a lot of AC$...-blocks in the drawing, so I guess you had a lot of crashes, the drawing structure is not clean at all.
- alfred -
Alfred NESWADBA
Message 63 of 65
pendean
Community Legend
Community Legend
This just proves that if you shared the file earlier, you'd be done and moved on by now 🙂
Message 64 of 65
Problem solved! Thanks everyone for all your help.  I totally would've tried the long method before if I had the time, busy day at the office.  But either way, thanks again for everything.  Have a great night.
S.Clancy
Message 65 of 65
Alfred.NESWADBA
Hi, look to PM(!) ... , - alfred -
Alfred NESWADBA
