Drawing is somehow Xrefed into itself
Message 1 of 65
I am currently working on a drawing and just relaized that it is somehow Xrefed into itself and I am unable to detach it.  Any thoughts?  Thanks in advance.
S.Clancy
Replies (64)
Message 2 of 65
Just realized I can't spell either.
Message 3 of 65
pendean
Community Legend
Community Legend
That's never an option: can you post that DWG file here?
Message 4 of 65
rkmcswain
Are you saying that because you see the name of the current drawing in the External Referenced palette?
R.K. McSwain     | CADpanacea | on twitter
Message 5 of 65
No, I am well aware the file name appears in the xref window.  thanks.
Message 6 of 65
No, I cannot post the drawing.
Message 7 of 65
It may not be an option, but it happened.  Thanks.
S.Clancy
Message 8 of 65
Alfred.NESWADBA
when you close the drawing, then use Windows Explorer to rename the drawing (so the name is different to which the XREF is pointing to) what happens then when you now open the renamed drawing?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 9 of 65
rkmcswain
Screenshots? Anything?
We can't really do much without some more information.
If not, can you revert back to a backup copy of this DWG, before this magical act occurred?
Message 10 of 65
When renaming the drawing and then reopening the program asks me to update the location of the xref.
Message 11 of 65
And detaching is no longer an option.
Message 12 of 65
Alfred.NESWADBA
Why, what happens when you try it?
Have you also tried command _CLASSICXREF to detach that file?
At least create a new drawing, save it with the old/previous name and if AutoCAD asks to update the XRef-path ... show this new file. That brings you to a stable state.
- alfred -
Alfred NESWADBA
Message 13 of 65
Just did, did not work.
Message 14 of 65
and sorry, when i try the drop down menu, detach is grayed out.
Message 15 of 65
Alfred.NESWADBA
The dialog of _CLASSICXREF does not have any pull down menu's. So what are you speaking about when you say "Just did"?
- alfred -
Alfred NESWADBA
Message 16 of 65
yes, I know.  I was referring to the regular xref panel.  in the classicxref panel the detach button is also grayed out.
Message 17 of 65
Message 18 of 65
rkmcswain
Have you run ._AUDIT?
Have you tried ._RECOVER?
What is DWGCHECK set to?
Was this DWG file edited in a non-Autodesk application?
Message 19 of 65
Load the reference manager and detach....
Message 20 of 65
Alfred.NESWADBA
have you tried my suggestions with renaming the file?
What I see in your screenshot is that you opened the file "XRef - Building.dwg" and a XRef is placed with the same name.
So if you
  • rename your drawing to "Building.dwg"
  • create a new (empty) drawing "XRef - Building.dwg" (save and close it)
  • open "Building.dwg"
..now you should have the option to detacth "XRef - Building.dwg" (I hope)
- alfred -
Alfred NESWADBA
