AutoCAD Forum
design for 3d printing
1 REPLY 1
266 Views, 1 Reply
I converted spine CT dicom file to dxf file.
I want to make hole inside the spine, but I can not do that.
I attached the file, if you can, I want to know the method.
Please, let me know.
1 REPLY 1
Alfred.NESWADBA
first run command _CONVTOSURFACE, that creates surface objects from your 3D-Faces.
Next start command _SURFSCULPT, that creates a 3D-Solid object ... and that object type can now be modified using boolean functions.
Good luck, - alfred -
PS: please find attached the result I did using AutoCAD 2016
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Forma Design Contest
