Rendering in AutoCAD
Message 1 of 10
Hi everyone!
I am doing some rendering in AutoCAD. I created 3D solid objects, i need those objects to render in plain white. I've tried applying a white material, i tried changing their properties to white, i've tried putting them on white layer etc. Nothing seems to work. When i rendering it the objects come out a greyish colour, what can i do????
Any help woul be greatly appreciated!
bye!
Alex.
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
Do you have lights shining on the object?
Message 3 of 10
Hi, yes I do. Not on them directly, but I did put 2 light in that scene. I also removed the shadow options.
Sent from my BlackBerry 10 smartphone on the Rogers network.
Please review the City of Brampton e-mail disclaimer statement at:
http://www.brampton.ca/EN/Online-Services/Pages/Privacy-Statement.aspx
Message 4 of 10
pendean
Community Legend
Community Legend
Any chance you can share that DWG file?
Message 5 of 10
Absolutely! Is there an e-mail address I can send it to?
Alex Burgos
Interior Design Services Technologist
Building Design & Construction
Facility Services Division
Public Services Department
P-905-874-3912
C-416-806-1542
F-905-874-3370
Alex.burgos@brampton.ca
Effective November 17th, relocating to City Hall Campus, West Tower, 8th floor
Message 6 of 10
m_kingdon
Just attached it to a post here
Mike Kingdon
Civil 3D Zealot
Message 7 of 10
Ok, how do I find the discussion there so many of them?
Alex Burgos
P-905-874-3912
C-416-806-1542
F-905-874-3370
Message 8 of 10
Alfred.NESWADBA
That's how "virtual realism" is doing it's job .. in the nature there does not exist anything with clean white 😉
As a sample: if you would have a box in your drawing, you look to that box so you can see three sides (front/left/top) and that object would be clean white ... you would not be able to see differences between the sides as you don't see the edge.
On the other hand: you would not be able to print the object (without any background) ... but to come close to clean white the option you have is to work with overexposure.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 9 of 10
Thank you! I've seen rendering produced in AutoCAD with plain white applied to 3D objects. I have everything set up with materials I applied to all my other 3D objects, I just to add white to a frames I built.
Is there any other way white can be applied?
Alex Burgos
P-905-874-3912
C-416-806-1542
F-905-874-3370
Message 10 of 10
Alfred.NESWADBA
can you show an rendered image + the drawing?
Just to make it clear for us what is "not white" for you (as all is relative when speaking about lightning and colors) 😉
- alfred -
Alfred NESWADBA
