AutoCAD Forum
convert autocad text to shp attribut
7 REPLIES 7
Message 1 of 8
marie-laurence.pollet
375 Views, 7 Replies
I have a dwg with several hundred boxes (closed polylines), and in each box I have a text (always different). I would like to export these boxes in GIS (shp ideally) with the texts as an attribute for each box. Is this possible? Thank you!!
7 REPLIES 7
Message 2 of 8
Hi Marie,
Not possible with vanilla AutoCAD. You'll need Map 3D or Civil 3D. The good news is if you have a current subscription to AutoCAD you can install Map 3D for no charge.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 8
Hi Dave, thanks for your reply! Actually I have civil 3D; so you have an idea?
Message 4 of 8
Marie,
Read >>>Here<<<.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 8
thank you I will try that! do  need to install Map or I can do it with civil?
Message 6 of 8
Hi Marie,
Most MAP features are also available in Civil3D, so you should be able to do it directly with civil.
Message 7 of 8
Civil 3D is built on top of Map 3D.
If you have Civil 3D then you have Map 3D.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 8 of 8
it works great thanks!!
Forma Design Contest
