AutoCAD 2021: How to create boundaries for multiple hatches in one go?
JamaL9722060
Message 1 of 8
JamaL9722060
I couldn’t figure out if there is a tool that can create boundaries for multiple hatches in one go
Jamal Numan
Replies (7)
Message 2 of 8
cadffm
Select them and start the command..
_hatchgenerateboundary
Sebastian
Message 3 of 8
rkmcswain
Message 4 of 8
JamaL9722060
Thank you guys for the help. Great that this tool is available out of the box!
Jamal Numan
Message 5 of 8
harryW4VU6
Is there any way to make the generated boundary associated to the hatch?
I need to use the stretch command to edit multiple hatches so they need an associated boundary.
Any help is appreciated.
H
Message 6 of 8
Kent1Cooper
Does it need to be STRETCH specifically?  Can you select the Hatches and their boundary objects collectively, and then use grip-editing, which will work on them together even if they're not associated?
But to answer your question -- I don't know of a way.  It doesn't look hopeful, as Help for HATCHGENERATEBOUNDARY is explicit about it:
and doesn't offer any option about that.
But it should be possible to come up with a routine that would do that, take information from the Hatch pattern, delete it, and make a new one, this time Associative with the boundary.  Would that serve your purpose?
Kent Cooper, AIA
Message 7 of 8
aadish_rahman
thank you very much
Message 8 of 8
JSvejkovsky
Thank you!
