convert autocad text to shp attribut
marie-laurence.pollet
I have a dwg with several hundred boxes (closed polylines), and in each box I have a text (always different). I would like to export these boxes in GIS (shp ideally) with the texts as an attribute for each box. Is this possible? Thank you!!
Replies (7)
Pointdump
Hi Marie,
Not possible with vanilla AutoCAD. You'll need Map 3D or Civil 3D. The good news is if you have a current subscription to AutoCAD you can install Map 3D for no charge.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Hi Dave, thanks for your reply! Actually I have civil 3D; so you have an idea?
Pointdump
Marie,
Read >>>Here<<<.
Dave
Dave Stoll
Las Vegas, Nevada
thank you I will try that! do  need to install Map or I can do it with civil?
Michiel.Valcke
Hi Marie,
Most MAP features are also available in Civil3D, so you should be able to do it directly with civil.
TomBeauford
Civil 3D is built on top of Map 3D.
If you have Civil 3D then you have Map 3D.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
it works great thanks!!
