AutoCAD Forum
Autosave file .sv$ won't open in autocad even after changing extension to .dwg
1 REPLY 1
juneaucathTN374
188 Views, 1 Reply
Hi!
I've renamed my autosave file extension from .sv$ to .dwg (making sure extension was visible) but the software just freezes when I try to open the file now. I restarted my computer and tried again but same thing. Any help?
Labels (4)
1 REPLY 1
@juneaucathTN374 Updated with drawing attached.
I inserted your drawing into a blank drawing.
Then I exploded it, saved it with a different name and closed.
Then I used the RECOVER command to open the new drawing & I received the following:
But now it successfully opens:
Though this method causes you to lose whatever you may have in your Layouts, at least you have all the objects you've drawn in Model.
Paul Li
IT Specialist
@The Office
Forma Design Contest
AutoCAD Beta
