@juneaucathTN374 Updated with drawing attached.
I inserted your drawing into a blank drawing.
Then I exploded it, saved it with a different name and closed.
Then I used the RECOVER command to open the new drawing & I received the following:
But now it successfully opens:
Though this method causes you to lose whatever you may have in your Layouts, at least you have all the objects you've drawn in Model.
