@juneaucathTN374 Updated with drawing attached.
I inserted your drawing into a blank drawing.
Then I exploded it, saved it with a different name and closed.
Then I used the RECOVER command to open the new drawing & I received the following:
![paullimapa_1-1717194271921.png paullimapa_1-1717194271921.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1370404i4A510CF44CA7DA01/image-size/medium?v=v2&px=400)
But now it successfully opens:
![paullimapa_2-1717194440575.png paullimapa_2-1717194440575.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1370405i225139707EB0E313/image-size/medium?v=v2&px=400)
Though this method causes you to lose whatever you may have in your Layouts, at least you have all the objects you've drawn in Model.
