AutoCAD Forum
AutoCAD 2015 display problem
2 REPLIES 2
754 Views, 2 Replies
I installed Auto Cad 2015 and followed the instructions. The software installed and the program works.
The only issue that I have is the auto cad Icon and the welcome screen are reduced in size and I cannot read any of the instructions or data. (instructional videos cannot watch them because they are ton small)
PLEASE ADVISE
@Anonymous,
john.vellek has edited your subject line for clarity: Auto Cad
2 REPLIES 2
Alfred.NESWADBA
Sounds like you have a 4K monitor which is not supported on AutoCAD 2015 (4K display support started with AutoCAD 2017 Update 1).
So I guess the only chance you have is to reduce the resolution (or update AutoCAD).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
rkmcswain
This sounds like you have a high resolution monitor, higher than is supported by that version of AutoCAD. Take a look at this document for some tips that may help.
R.K. McSwain     | CADpanacea | on twitter
Forma Design Contest
AutoCAD Beta
