Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
ACAD2017 - Layer pane is empty
Wheelie22
Message 1 of 17
Wheelie22
Not the first time but after a few views its like this :
The only way to get it back is to restart acad.
Hardware :
Replies (16)
Message 2 of 17
pendean
Community Legend
Community Legend
What if you turn off hardware acceleration then test it out for the day?
It's important that R2017 is fully patched and updated too.
Message 3 of 17
john.vellek
Hi @Wheelie22,
I agree with Dean that it is important to have your application fully up to date.
You can also check your graphics card driver to see if there is a newer version that might correct the issue.
Did this behavior just start occurring and in all drawings?
John Vellek
Message 4 of 17
Wheelie22
Hello @pendean and @john.vellek
This is my current version :
I am going into test mode and turned the hardware off.
Message 5 of 17
Alfred.NESWADBA
from your versions list: your AutoCAD is not up-to-date.
Please use the Autodesk Desktop App, make sure you are logged in, after a bit of time it will show you the Update 1.2
Other method: login to your >>>subscription center<<< and find the update 1.2 in the product-updates section.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 6 of 17
john.vellek
Hi @Wheelie22,
You can also find the remaining updates in your Account Management page.
Please add a post with the status of this issue after you have applied the updates.
John Vellek
Message 7 of 17
Wheelie22
Ok i now have the 1.2 update and try the layer pane
Message 8 of 17
Wheelie22
The layer pane is ok, but now (sometimes) the buttons are gone.
I will try to get support to look for new drivers for the graphic card.
I had to change this one to off:
Else the WD-IEC font looks like this :
Message 9 of 17
GrantsPirate
If the lower left Invert filter box (in the layer properties manager) has a check mark in it that will be the result.  Look down there next time to make sure that is not checked.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 10 of 17
john.vellek
Hi @Wheelie22,
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Message 11 of 17
Wheelie22
There are no new drivers for my PC.
I had to change the High Q. to off.
Else the WD-IEC font looks, depending on the (scroll) zoom, very bad. Like the problems we have with this font in the PDF.
Maybe we have to stop using this font ?
So no accept as solution.
Message 12 of 17
Alfred.NESWADBA
Please try at position 1 of my screenshot if you can move that (with the cursor, left/right) and/or restore the filter part in the dialog (2):
Please:
  • is it a SHX or a TTF font? Start command _STYLE, on the left side select the style that uses the font, then create a screenshot from that dialog and show this screenshot here
  • does the same bad display happen if you start a new drawing based on an original AutoCAD template, create a text-style using that font, create a text using that style ... same issue?
- alfred -
Alfred NESWADBA
Message 13 of 17
Wheelie22
No, that is the separator line.
Normaly it looks like this :
And this is the default font for acad-E, the isocp2.shx.
Message 14 of 17
Alfred.NESWADBA
Ok, and how about the filter-min/max icon "2" in my screenshot?
Sorry, this here is the AutoCAD forum, so I can't know that from your previous post "WD-IEC font" was meant as "WD-IEC" is the style and that style is using "ISOCP2.shx" font 🙂
What happens if you change the style so it is using ISOCP.shx or ISOCP..ttf instead of ISOCP2.shx?
This question is open:
- alfred -
Alfred NESWADBA
Message 15 of 17
RobDraw
I've had this happen before through many versions and computers. Some more often than others. As far as I know, there is no fix. Changing workspace or profile and then changing it back has worked but only temporarily.
Some suggest using the classic layer manager.
Rob
Message 16 of 17
Wheelie22
I dont see no. 2 now that >> is gone. How did i get that ?
Wrong forum : it started with the layer, and the iso font has Always been in ACAD. I have acad 2.5 on a floppy, and its there to.
(i think, don't have a computer with a disk drive) Smiley Embarassed
But thaks for the reply
Message 17 of 17
Alfred.NESWADBA
>> Wrong forum :
No, not the wrong forum for the question.
But you expected that I should have known that "WD-IEC" is a style and not a font PLUS "isocp2.shx" is a default font in your application ... and that is not clear to all people answering AutoCAD questions here (and not using ACAD-E).
Yes, but never been a default setting in AutoCAD 😉
Interesting, you have shown this on your first screenshot ... I made my screenshot from your picture 😉
What happens when you move the layer-manager to the other display, then close and reopen it?
That's how I get the missing icons and display issues with the layer-manager repaired on systems only having a Intel-GC.
Questions open:
  • What happens if you change the style so it is using ISOCP.shx or ISOCP..ttf instead of ISOCP2.shx?
- alfred -
Alfred NESWADBA
